Results 1 to 2 of 2
Thread: AE101 4AGZE interchangeability with other 16v GE/GZE models?
    Brisbane
    Default AE101 4AGZE interchangeability with other 16v GE/GZE models?
    I'm fairly close to buying an AE101 4AGZE half cut.
    What stuff is interchangeable? eg:
    can I use a flywheel from an AW11
    will the headers from my AE82 4AGE bolt up to the AE101 head fine?
    can I use cams & cam gears that suit atmo 4AGEs, etc?
    if I buy a timing belt kit for say an ae92 gze will that fit or are they model specific?
    Victoria, Mt Macedon
    Default Re: AE101 4AGZE interchangeability with other 16v GE/GZE models?
    Almost everything is interchangable.
    Any 4A flywheel with 8 bolts will work (just the 6 bolt 4AC won't), as long as it fits in your bellhosuing.
    Exhaust port and bolt spacing is the same across all 16V 4AGs. 20V have 2 exhaust studs moved slightly, ports are the same though.
    All 16V cams and gears are interchangeable. Only thing to note is that exhaust cams have a dizzy drive on them. So exhaust cams can be used on both sides, but intake cams can only be used for intake if you still run a dizzy or CAS.
    Get a timing belt kit for any 16V 4AGE and it'll fit.
    Hen
    By The Witzl in forum FAQ
  2. can other 4AGZE blocks be used with AE101 loom (essentially)
    Last Post: 07-02-2007, 06:23 PM
  3. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
