clutch fans usually move more air than thermos, so you have to increase the efficiency of the thermo
ideally the thermo should be mounted in a shroud, the shroud should cover the entire radiator and the thermo should be a small distance away from the back face of the radiator not directly on it
similar to any standard shroud setup
here is a pic of factory AU falcon thermos .
