Results 1 to 3 of 3
Thread: 4M overheating problems
    Junior Member Grease Monkey Brad-KE35's Avatar
    Default 4M overheating problems
    Hey all,
    Guys my clutch fan recently shat it self so I replaced it with a 16" thermofan, I have placed it on the engine side of the radiator with it sucking air thru the rad and onto the motor, now the car sits on around 3 quarters on the temp gauge, just a whisker away from the 'H'. Having the thermo how I do, is this the best way to keep the motor cool?
    By the way its a MX32 Cressida.
    Any help would be greatly appreciated.
    Brad
    1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
    1994 Ford Falcon Pedovan - Rape Dungeon
    Default Re: 4M overheating problems
    clutch fans usually move more air than thermos, so you have to increase the efficiency of the thermo
    ideally the thermo should be mounted in a shroud, the shroud should cover the entire radiator and the thermo should be a small distance away from the back face of the radiator not directly on it
    similar to any standard shroud setup
    here is a pic of factory AU falcon thermos .
    Feb 2009
    See if you can mount the thermo inside of the original fan cowling where the original fan would sit.Fixed.
  1. 4M engine kickdown on carby
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 06-05-2009, 10:10 PM
  2. aw11 overheating problems.
    By Brendan in forum Tech and Conversions
    Last Post: 07-04-2008, 04:16 PM
  3. Problems solving 4agze
    Last Post: 28-06-2006, 06:21 PM
  4. Cooling Systems - Overheating Problems.
  5. Overheating problems. 7M-GTE
    By 7mSupra in forum Tech and Conversions
    Last Post: 04-01-2006, 11:01 AM
