Results 16 to 23 of 23
Thread: Brake pad diagnosis
    Default Re: Brake pad diagnosis
    Bendix ultimates are definitely not up to serious track work.
    Spending money on pads is one of those things that is worth doing. You might spend more initially but they will last longer and stop better, saving your money in the long term.
    My little Corolla uses a pad made by Racebrakes here in Melbourne. $200 for a set and they are excellent. I forget what the spec was on them, but he makes his own.
    Might be worth a phone call to him and ask what he reckons you should be using. He is good with assistance like that.
    Now - RA23-WRX
    My DS2500's have worked well, good bite and haven't had them fade. They were $180 to my door.
    I may try the DS3000's next time but after this experience with the DS2500's I might just run them again.
    My KE25 thread
    Melbourne Victoria
    i use ds3000 on the front and ds2500 on the back and i sometimes drive this to the dyno in peak trafic and they stop fine
    ps they are good on discs but a little dusty
    Quote Originally Posted by Celica RA45
    What's the warm up like on the DS3000's compared to the DS2500 which don't require much heat at all to be in their working range?
    My KE25 thread
    Melbourne Victoria
    they can squeal a bit when cold but still pull up or right
    i have used this pad now for 5 years and have tried harrop rotors and AP rotors and even DBA rotors and they take to each cast iron rotor no problems and there the only pad that seems to work on any rotor
    with hawk blues around the street they use to hard on disks etc
    Really?
    I'm using DBA rotors, and the hawk blues haven't touched them in... 2 years?
    New Zealand
    Quote Originally Posted by SilverRA23
    Racebrakes here in NZ use the Mintex compounds, its likely what you've got.
    Callum
    Forum Sponsor Conversion King
    Quote Originally Posted by Draven
    Really?
    the drivers side rear would argue that
    light cars dont like aggressive pads due to not using the brakes heavily enough on the street, heavier cars can get away with it though due to the extra energy heating the pad and disc quickly.
    Quote Originally Posted by Shifty
    Oh, and you mentioned you were "losing the pedal".. if you mean the pedal was going to the floor then that's a hydraulics issue... if you mean the car just wasn't stopping despite the pressure on the pedal then that's a pad issue.
    you can have a loss of pedal due to a cooked pad aswell.
    linden
    By The Witzl in forum FAQ
  2. MS50/60 & 70 Front brake upgade - By Shep
    By TheToyman75 in forum Tech and Conversions
    Last Post: 04-05-2009, 08:34 AM
  3. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 10:26 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
