Results 1 to 5 of 5
Thread: keep blowing indicator fuses randomly
    Apr 2009
    wa
    Question keep blowing indicator fuses randomly
    i have a 1990 diesel hilux that keeps blowing indicator fuses at random ,
    sometimes when running , sometimes when i turn car off,can't find a short anywhere.
    any ideas?
    Default Re: keep blowing indicator fuses randomly
    You may not have a short, but it certainly sounds like a bad earth. Has the car recently been repaired/repainted? Run around and undo each earth, clean and reconnect.
    cheers Chuck.
    MS51Crown Coupe,
    Also check the bulb holders and the indicator switch itself and the loom inside the column.
    Feb 2007
    Timaru
    Will have nothing to do with the indicators.
    Will be the reverse light switch wiring on the gearbox,
    or if it's 4wd it may also be one of the switches on the gearbox for that.
    They are on the same fuse,
    quite often the wiring breaks and shorts out,
    or melts onto the exhaust.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Apr 2009
    wa
    Thumbs up Re: keep blowing indicator fuses randomly
    thank's for the reply's every one, problem seems to be sorted, not sure if it was the bad earth or not but i was fixing wiring probs to the stereo/clock and spotlights and now i'm not blowing fuses anymore , had few earth's undone maybe thats all it was?
    again thanks for all the help.
  1. Keep blowing efi fuse
    By Intense in forum Tech and Conversions
    Last Post: 31-08-2008, 10:11 AM
  2. GT4 Blowing smoke?
    By Sledge in forum Tech and Conversions
    Last Post: 04-05-2008, 02:06 PM
  3. RA28 Diff - They keep blowing - What can i do ?
    By KZN130_Surf in forum Tech and Conversions
    Last Post: 30-08-2007, 10:34 AM
  4. 7mgte blowing smoke need advice
    By Mk3_supra in forum Tech and Conversions
    Last Post: 24-02-2007, 09:06 PM
  5. Boost Blowing Out The Spark?
    Last Post: 01-10-2006, 06:34 AM
