Results 1 to 15 of 29
Thread: RA28 Diff - They keep blowing - What can i do ?
    Junior Member Grease Monkey KZN130_Surf's Avatar
    Default RA28 Diff - They keep blowing - What can i do ?
    Hey guys,
    I keep blowing diffs on my RA28 and i have no idea why...
    No burnouts or any of that s#!t, they just keep blowing...
    Any ideas...?
    Is there another option ? Possibly a bigger, stronger one, like a hilux diff or something ?
    And how much is that gonna cost me...?
    Kenno
    Green 1993 KZN130 Hilux Surf
    Black 1977 RA28 ( Sold )
    2008 DHZ 140cc pitbike
    Default Re: RA28 Diff - They keep blowing - What can i do ?
    bout a $1200 and you'll have a hilux diff under the car
    hilux diff ~$500 unless you get lucky like me
    go to diff shop, get mounts off t series onto g series ~$400
    custom tailshaft $150 to shorten, $450 for a complete 1 piece
    lsd centre about $300 - $400
    4 real
    will my 18R-C b able 2 handle it, it puts out about 70-75kw atw...
    volvo 240 diff $100-200 at wreckers, 264mm solid disc's, twin piston calipers
    masive unbreakable axles, centres are almost indistructable, (ive broken one...from giving it everything at the drags)...
    swap mounts over,
    then you dont have ghey drums like the hilux's and you dont have to fork out extra cah for the disc conversion....
    blake
    EDIT: plus there is atleast another 50 threads on this same topic, its all been covered before, try searching
    Sounds good... Is it an easy conversion..?
    sorry i just assumed you had a 18rg or 1g or 1j or something
    yeah go volvo, what have done to your 18rc that it fries t series diffs
    i tried my hardest to break mine with a worked 2.2L rg and couldn't
    I've done regular clutch dumps from 6000-7000 on a standard T series ra23 with 1g-gte. I blew one diff in 3 months, the second one is still going. Your problem could possibly be with a bent housing. I went through 6 diffs in a kingswood, some would blow with no stress at all, turned out the actual housing was bent, and overstressing everything. Might be worth looking into, otherwise I like the borg warner diff's. strong, light, easy to get LSD centres, good choice of ratio's etc
    I dont know ayy, its just rebuilt with a rebuilt minuki carby with big jets & a h/d clutch...
    goes pretty hard...
    Well ill get on 2 it...
    Thanks guys...
    There's no point spending that sort of money on a diff conversion when you have an 18R-C. Obviously something is awry if you keep blowing them, a stock T series diff should be more than adequate for that sort of power. Take it to a diff shop and get their opinion, could be something like a bent axle? How exactly do they break?
    Montrose
    I've always found that putting oil in diffs after putting them back together tends to make them last sooooooo much longer...
    Junior Member Backyard Mechanic sleeektoy's Avatar
    Jan 2007
    Auckland
    Bent axle, imbalanced driveshaft, crap in the oil etc etc can all lead to very premature diff failure. I have a 2T-G with 100kw @ rear wheels and havent blown a std diff racing it and doing autocross's/motorkhanas.
    Well ill try the volvo diff...
    Do all the arms match up ? is it a straight swap ? same compression & all...
    Straight swap from a Volvo to a Toyota? In your dreams!
    Any diff swap will require cutting and welding, ie unnecessary expense. Find out why you're blowing stock diffs first, this should not be happening!
    agreed ... check out your current 1 first.
    are you breaking centres ? axles?
    normally a T will munch the centre 1st .... once you lsd or weld the centre then the axles start going from what ive witnessed.
    i dont think even a on the spot ripper from a RC could even make a T diff laugh let alone break .... smething has to be wrong.
    Black Betty >HERE!<
    (\__/)
  1. diff problems
    By Born-Enthusiast in forum Tech and Conversions
    Last Post: 24-06-2007, 10:38 PM
  2. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
