Results 1 to 11 of 11
Thread: KE70/AE86 engine bay dimensions
    New Zealand
    Default KE70/AE86 engine bay dimensions
    Need some measurements from a KE70 (or AE71, AE86) engine bay but my engine is making it dificult get be accurate enough. If anyone has an empty engine bay or a chassis dimensions book can they get the measurements between the chassis rails as marked in the photo below. Also some measurements around the clearance for the steering column would be handy (how far from rack to chassis rail etc) as my rack has been moveed over for engine clearance.
    Thanks
    Callum
    Default Re: KE70/AE86 engine bay dimensions
    1 = 670
    2 = 710-730 depending if you go off the top of the rail or the wider section halfway down
    3 = 770 measured inline with the front bolts for the bumper.
    ive got the book with the engine bay measurements, but it doesnt give you those measurements.
    my crossmember and steering column are out so cant help you with the other dimensions.
    can scan the page from the book if you want me to?
    New Zealand
    Scan would be sweet, just need to check a possible engine fitment....
    Callum
    http://s29.photobucket.com/albums/c2...body%20manual/
    see how you get on with those.
    if theyre not clear enough i can get scans, just means ill ahve to use the old mans computer coz he blocked the network with his wonderful antivirus shit, and that computer annoys me...
    New Zealand
    Those are perfect, cheers. Now I just need to crawl under my Hilux and do comparative measurements.
    Callum
    haha, what are you thinking of putting in it?
    4wd ke70 now?
    New Zealand
    Haha, no. I just know the clearances of this other motor in a Hilux and happen to have one the same model to compare.
    Callum
    what motor is that wide at the bottom?
    you have to tell us
    New Zealand
    Motor no prob, just really checking exhaust. Fits inside Hilux rails so confiming it will fit on Corolla without major expensive work.
    Callum
    i thought that may ahve been the case, exhaust on passenger side?
    i can get measurements around steering column off my other car the next time im at the workshop if you need those.
    i know how fun it is to fit an exhaust around the steering shaft...
    oregon
    AE86 dimensions -
    AE71 Dimensions -
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. Toyota R Engine History
  3. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  4. MA70 --> JZA70 Conversion
