Just remember That it's not just one wire needed to install the immobilizer.
You need to find :
- A constant 12v Source, you splice the appropriate wire from your Immobilizer into the cars wire
- The Ignition wire, you splice the appropriate wire from the Immobilizer into this wire, this is to give a signal to the immobilizer for when the car is off and on. From Looking at the Diagram it looks like this is the Black/Red Wire.
- You will also need to run one wire through the immobilizer, such as the wire for the Startor Motor. From Looking at the Diagram it looks like this is the Black/White Wire.
