Results 16 to 26 of 26
Thread: bp vs sp cams
    Default Re: bp vs sp cams
    Quote Originally Posted by -GT-
    Do you perhaps mean;
    or;
    because i think you'll find
    I meant that if you shift the torque peak lower down the rev range, peak power will decrease but the curve will fatten up (so mean power like you said), and can result in a faster car overall.
    New Zealand
    ok, lets clear some things up.....
    ae82 didnt get the later bigport (42mm crank 7 rib block) the late aw11s did
    4agze does appear to get a small gain, 4age does not. but its not worth the work to do it unless you already have it apart
    4agze has THE EXACT SAME cams as 4age.
    ae86 had exact same cams as same year FWD engines
    after searching my memory, i do recall that the cam change was with the change to the 42mm crank version.
    please, no more PMs!
    Quote Originally Posted by Mr Revhead
    From what I've been told by multiple people, Series 3 AE82s (the last of the run) _did_ get the 7-rib bigports in Australia. I haven't seen much if anything in the way of official documentation confirming it however.
    Brisbane
    Quote Originally Posted by Talasas
    We swapped a head on a mate's Smallport for a cleanly built one with Bigport cams, after a clean tune with an eManage he gained 16 kW at the wheels. That is with the stock cam gears. The reason you'll find it's hard to get results from people is because very few can justify swapping 1 item that's so time consuming and getting an average dyno reading for a before and after. Often we tend to bundle the jobs into one so we swap several things at a time while x and y are removed/apart etc.
    The number of times I see people make a change, but not adjust the tune to suit, is staggering. Someone up further said a guy dyno'd it and got a negative result... I bet he didn't dial them in & tune it to suit.
    New Zealand
    aussie assembled one? i guess thats possible
    ok, JDM and NZ new ae82s DIDNT get those big ports
    I'd be guessing that because we kept the AE82 longer than Japan (they were selling AE92s in 1987 with the 7-rib), Toyota Australia swapped to the 7-rib during the overlap period. Would explain why there are so many of them around in AE82s, even if they're not standard (MAP, because AW11 ones are AFM, aren't they?)
    Sep 2008
    aw1 run AFM, (the aussie delivered ones) teh jap imports where map sensored
    The GOD HAND AW11 - sold
    Times like this that you wish Toyota would have just picked one style and stuck with it....MAP, AFM, MAP, AFM, MAP, it just kept alternating (3-rib MAP, 7-rib AFM sometimes, smallport MAP, silvertop AFM, blacktop MAP)
    Sep 2008
    yeh it is rediculous if you think about it...
    i have heard of a AFM smallport from USA but never seen one, except for my one but that is because it is running bigport electrics...
    New Zealand
    its not that bad.... they did tend to do changes across the board at the same time.
    its just different markets got some different things on the outside, like ECUs and AFM/MAP.
    longer production run would make sense, as at X date they stopped putting bluetops in cars and started with redtops
    Chiba
    This I can confirm. I measured my stock AE101 4AGZE cams to be the same as the smallport when I put the bigport cams in (which had the bigger lift and duration).
  1. Toymods and CAMS Affiliation
    By twentyEight in forum Toymods Car Club Membership and Feedback
    Last Post: 19-11-2007, 03:11 PM
  2. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  3. 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    By craigy in forum Tech and Conversions
    Last Post: 07-04-2006, 03:00 PM
  4. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
