Results 1 to 6 of 6
Thread: Warning light on Dash jzs147 Under Braking
    Default Warning light on Dash jzs147 Under Braking
    Hi All,
    Recently i've noticed under med-heavy braking I have a light that comes on on the dash. The light is the ! inside a circle. The only time this light used to come on was when the handbrake was on. Because it only comes on during higher g forces i assume it's a liquid somewhere. I've checked oil for both engine and trannie, radiator coolant and brake reservoir too. All are perfect. Engine has no mods except for airfilter.
    Umm, it's got me stumped. Any ideas would be much appreciated! It's getting pretty annoying.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Junior Member Grease Monkey Mr.Phreak's Avatar
    Feb 2007
    New Zealand
    Default Re: Warning light on Dash jzs147 Under Braking
    Brake Fluid, try overfilling it slightly
    Or you've got a loose connection on the handbrake
    It will be for the brake fluid - a low level warning coupled into the handbrake light. Although you say you have checked it and its ok - but it could be that the g-forces are enough to move the fluid to cause the light to come on.
    Is there a max level in the reservior as wearing pads will cause more fluid to be stored in the calipers - which is why it might not have happened from the start?
    As above, brake fluid level - or a loose wire/bad earth that moves enough to short under heavy braking.
    Toymods Club Member
    Thanks all, will throw some fluid in it tonight and see what happens!
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Check the level, then top it up if it needs it.
    Toymods Club Member
  1. Bulb Blown warning light
    By skelz in forum Tech and Conversions
    Last Post: 26-04-2006, 09:56 PM
  2. JZZ30 Dash Warning Messages
    By fingers in forum Tech and Conversions
    Last Post: 06-04-2006, 05:37 PM
  3. ST162 warning light?!?!
    By XiL3D in forum Tech and Conversions
    Last Post: 08-03-2006, 03:03 PM
  4. Alternator Warning Light Wiring
    Last Post: 04-01-2006, 10:32 PM
