Results 16 to 21 of 21
Thread: TA22 Master cylinder upgrade with Hilux calipers?
    Default Re: TA22 Master cylinder upgrade with Hilux calipers?
    Thanks mate ~ put into favourites (wont lose it now)
    ... hope there are still some Pajero's left out there !
    Junior Member Domestic Engineer TA22 GT's Avatar
    Yep, I used the Pajero unit with the white cap as I needed the low level switch for my OK Monitor
    Sep 2011
    I have the Pajero unit with stock rear brakes and xt130 twin pots on the fronts and the pedal is very stiff
    I have the PAjero with 4 pot LN106 up front and twin spot rear discs and it's good. I used to have twin spot up front with the stock unit and it was fine....
    May 2011
    Tonyger the XT130 brake m/c is only a 7/8" I believe so having the larger 15/16" pajero m/c you would get a hard pedal... same theory as I mentioned previously with the 1" m/c on the 4 pot hilux calipers that are designed for 15/16" m/c.
    Cheers Josh
    Sep 2011
    Quote Originally Posted by Josh_TA22 View Post
    Cheers Josh
    That makes logical sense
    It's just others who don't get a hard pedal that i wonder. I'd love a slightly softer pedal.
    By The Witzl in forum FAQ
  2. TA22 master cylinder with 1 inch bore?
    Last Post: 19-06-2007, 09:22 AM
  3. brake master upgrade for corona???
    By sam-131 in forum Tech and Conversions
    Last Post: 18-02-2007, 04:47 PM
