Results 1 to 15 of 18
Thread: 2JZGTE A340E Shift Kit
    Default 2JZGTE A340E Shift Kit
    Does anyone have any information on shiftkitting an A340E out of a JZS147 Aristo?
    I recall Dennis did it in the same fashion as 1JZ that is shown on supraforums if I recall correctly... but I think he also mentioned issues with it not working that well due to the line pressure being controlled by the ECU??
    I don't want to turn the gearbox into something that chirps gears on every gearchange, but I would like something that shifts a little bit quicker.
    It's still a daily driver.
    MV do an exchange valve body I beleive, but not sure if they do a parts and instruction set (Not sure if MV has some cores in stock...)? Has anyone bought an MV exchange valve body? Experiences?
    When I get a chance I'll put up a graph that shows gear shift timing currently.
    Wilbo's JZA80
    Wilbo's JZZ12
    The Fonz Grease Monkey rob_o's Avatar
    Default Re: 2JZGTE A340E Shift Kit
    I have a MV Automatics Stage 1.5 shift kit. It shifts nice and firmly, but not hard enough to chirp on gear changes.
    1JZ Toyota Cressida Grande
    Have you considered just shimming the acumulators ? (I think this is the right terminology).
    Indeed I have, but I'll be honest I don't currently know enough about auto's to know if this will give me a good result.
    I'd like to know exactly what MV do in their shift kit...
    Wilbo's JZA80
    Wilbo's JZZ12
    Check epic time between 1st to 2nd shift...
    Wilbo's JZA80
    Wilbo's JZZ12
    about half a second?
    I bought a MV automatics stage 1 shift kit for the a340e in my mx83. It came with fitting instruction and Michael was extremely helpful over the phone. I could not speak more highly of MV automatics and I would happily recommend them to anyone.
    It is so rare to find someone in the automive industry that is knowledgeable, competent, helpful and reasonably priced.
    Tell us the price son.
    i got a stage 1 shift kit for my aristo 2jz conversion, and it shifts really hard almost under any load.
    my brother got a 1.5 with his 1jz mx73 and that seems a lot better than mine ie smoother under low load and chirps under high load.
    i have taken it back because it cause a few problems ie: my car being impounded for 48 hours under the hoon laws but there was no fix and i have just learned to live with it.
    Quote Originally Posted by PlacentaJuan
    i call shenanigans - a harsh shift kit doesn't make you drive like a bogan
    Act
    nah you need to know the story Juan was hard done by
    Nov 2007
    Wouldn't you have to turn up the line pressure as well as shimming the accumulators, and if line pressure is controlled by the ECU then it may be a problem, I know in earlier A340E's there is something inside the box that you turn to increase the pressure.
    Quote Originally Posted by Z2TT
    yea that what i reckon; the 1jz autos have a mechanical cable running to the tranny that controls kickdown and line pressures, in the aristo its all electronic.
    prolly why all the onejay guise are all like "yea i have a shift kit and its sweet es brew" and we are all like "why wont my shift kit work on my 2j and i keep getting my car confiscated and junk?"
    Nov 2007
    So without being able to modify the ECU, is there any way to get a good shift kit on a 2jz A340E, do MV have anything?
    Thanks.
    Thanks.
    i wouldnt be suprised if he can do something now a lot better than i got a few years ago.
    he did some pretty interesting mods to my gearbox that was a first as far as i know, so he is pretty clued up and keen to tackle new problems.
  1. How to install MV autos shiftbox into A340E
    Last Post: 19-07-2012, 07:37 AM
  2. A340e maual shift kit
    Last Post: 02-05-2008, 09:21 AM
  3. GUIDE: Changing your Gearbox Shift Solenoids (Cressida MX83)
    By johnnilicte in forum Tech and Conversions
    Last Post: 05-11-2007, 05:42 PM
