Results 1 to 5 of 5
Thread: 2TGEU running rich!!!!
    Nov 2008
    Default 2TGEU running rich!!!!
    I have just finished fitting a 2TG with factory injection into an old RT40 corona, the AFM unit of is from a 22RE engine as I was unable to locate a genuine 2TG AFM. The engine is running but it is very rich. Has anyone got any sugestions on how this can be rectified? I also noticed that when I remove the black cover off the AFM there is a contact switch that is held open when there is little or no air being drawn through but closes when the engine is running, if i hold this open the engine seems to idle nice but when i let it close is goes back to running rich and rough.
    Default Re: 2TGEU running rich!!!!
    The contact is for the fuel pump control relay. So the fuel pump is only running when there is airflow (i.e. engine running).
    You should be able to adjust the tension on the AFM flap so it takes more airflow to move the flap (thus leaning it out a bit).
    Moderator Grease Monkey Pumpkin's Avatar
    Make sure you hold the cog before adjusting the tension..
    If you pull the lever away from the cog, it will spin wildly and then your kinda screwed..
    Dyno would be the best way to tune it... I thought the 22RE airflow meters were considerably bigger than the 2TG?
    Pumpkin
    2TGEU Mustard TA23 -- It's back... Just not in one piece .
    M-EU White MA45 .. -- SOLD...
    Audi A4 1.8T .. SOLD
    Nov 2008
    How do I modify the mixture? WIll not using the origional AFM cause the problems I am having?
    Daniel
    The electronics are matched to the afm and the fuel injector size and the engine, using mismatched components will have unknown results.
    http://www.4x4wire.com/toyota/minutemods/afm/ for guide mate.
  1. 1g-gte running rich and bad idle
    By Z2TT in forum Tech and Conversions
    Last Post: 16-10-2008, 03:13 AM
  2. 4age 20v Blacktop, Fuel mix to rich
    By Scoobzd in forum Tech and Conversions
    Last Post: 29-07-2008, 03:17 PM
  3. 18RG running too hot
    By shewiththe18RG in forum Tech and Conversions
    Last Post: 29-10-2007, 07:59 PM
  4. running in my new engine
    By hypo23 in forum Tech and Conversions
    Last Post: 21-09-2006, 06:05 PM
  5. 7MGTE running rough, SAFC Related
    By doobs in forum Tech and Conversions
    Last Post: 19-06-2006, 10:53 PM
