Joel as the guys have said when did you last change your fluid ??
Something so you know the difference next time ..
( 1 ) Boiled fluid will cause you to loose the pedal as in the pedal will go to the floor or a lot longer travel ( This above situation is only relevant under hard driving, if its doing it under normal driving you probably have a master cylinder issue, but thats another story )
( 2 ) Cooked pads the pedal stays pretty good good height wise ( no real difference ) but seemingly no matter how hard you push the car doesn't really feel like it slowing down & you will smell a VERY strong brake odour as well ..
