Right... pedal to the floor is a fluid problem, not a pad problem, that is if the MC is good.
A pad change isn't going to fix this. Pad fade gives you a hard pedal but not slowing down.
So... bandaid fixes would be:
- DOT 5.1 for the higher boiling points. Fluid should be changed after "pedal to floor" boiling incidents anyway.
- I'd try to direct cooling ducts at least partially at the caliper, in hopes of helping it get rid of the fluid heat. Cooling via the disc has less effect on caliper temperature, where you need it the most.
The only "real" fix would be an increase of rotor surface area e.g. go even larger. Stock brakes might have lasted 2-3 laps or less. However, track racing is hell on brakes, apparently enough so, that even your current setup lasts just 10 laps.
Another bandaid - one to be applied with much care - could be a water spray. You need a fine mist if you don't want warp or even crack stuff, and never mind the steam clouds![]()
