apart from that, it is probably a good idea to swap the thermostat at the same time.
if the inside is really rusty, (and even if not) you might want to flush it out before fitting the new stuff... ie remove the thermostat, and stick hose on the inlet pipe (the one going to water pump) and blast water through there...
you can use running water (mayeb not in current water restrictions????) from hose to do it.
