I have a 2TGUE with factory injection system, now the car is only running on 2 cylinders, there is spark on all cylinders but seems to be no injector firing on cylinders 2 & 4????. I swapped the injector plug from no.4 injector onto no.3 injector and it still is only running on 2 cylinders (1&3) so it would seem that the wiring to the injectors is ok? Has anyone got any ideas or has come accross this before?
Cheers, Daniel
Sounds like your injectors are stuck/clogged. You could pull one of the non firing ones out and swap it with a firing cylinder. If that one doesn't fire then you've found your problem. Get injectors cleaned and then no more problems.
AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
AE86 shell - waiting for a donor car from the auctions.
