Results 16 to 19 of 19
Thread: JZA70 draining battery.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default Re: JZA70 draining battery.
    Simple is always good.
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Quote Originally Posted by Gavatron
    • Have the car off, no accessories or ignition.
    • Get your multimeter out, plug the positive probe lead in to the 10A terminal.
    • Disconnect the negative battery terminal.
    • Put one lead on the negative post on the battery and one lead on the negative terminal. Don't let the negative terminal touch the negative post on the battery while doing this.
    This is how much current the car is drawing constantly. It should be fuck all, under .1 amps or even less. If it draws more, you start unplugging shit or pulling fuses until it goes away. Whatever fuse you pull/thing you unplug when it drops is what is draining the battery.
    Will have to give this a go..
    Cheers, Gav.
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Make sure the key is off, the door is closed, and all the interior lights are out when doing this test, otherwise you'll get false readings.
    The only things that should be drawing any power are ecu memory, radio memory, clock memory, trip meter memory, and immobiliser/alarm.
    My guess is something from the conversion isn't wired properly, and as suggested a relay is staying on.
    Gone from 005 to XR5! Automotive Encyclopaedia Matty P's Avatar
    My money is on your headunit. I had the same problem in the AE82, had no alarm, immobiliser, amplifiers or anything. Power was wired straight to battery.
    I cut the wire to the battery - no more problem...
  1. Weird Battery Drain
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 16-01-2009, 10:23 AM
  2. blue phosphurous stuff from leaking battery
    Last Post: 21-07-2008, 08:15 PM
  3. Stock/Standard JZS147 Aristo Battery CCA Rating?
    By Esteban in forum Tech and Conversions
    Last Post: 09-10-2007, 07:40 AM
  4. St18x : Rearmounting the battery
    By Classique71 in forum Tech and Conversions
    Last Post: 07-02-2007, 12:03 AM
  5. What the hell is draining my battery?
    By WHITCHY in forum Tech and Conversions
    Last Post: 10-03-2006, 09:17 AM
