Results 1 to 13 of 13
Thread: T18 Wiring Diagram???
    Backyard Corolla Kid Grease Monkey
    Default T18 Wiring Diagram???
    im in need of a wiring diagram for a T18/TE72...
    in particular the engine bay diagram...
    i need to wire up my coil, as the standard coil wire's were cut out when i converted to 4age...stupid wiring guy did it without telling me...
    this is one of the last things i need to get the car running
    any help is appreciated
    Default Re: T18 Wiring Diagram???
    bump...still need some help with this
    Junior Member Grease Monkey Beserker99's Avatar
    Yo!
    I got the complete wiring diagram...but no working scanner.
    If ya can wait till work resumes, I can scan it there and post it up for ya
    Or I can prolly send ya some MMS's if urgent...but I don't know how to read wiring diagrams, so I might not know if it's useful at all.
    yeh if you can scan it up when you get back to work that would be great...
    cheers man
    nuts Grease Monkey
    auckland
    pretty sure a 4age coil is powered through the engine loom to the ignition switch which is same source as the t18? which means you connect up t18 coil wire as factory and run straight to coil positive terminal. pity rwd bluetop loom (or ae82 4age loom) will end up with coil on l/h side when mounted in rwd... opposite side of t18 coil. so good idea to pull coil and ignitor wiring back across top of engine and exit the loom out on r/h side.
    saw some t18 (lhd) diagrams on this site
    http://home.insightbb.com/~jmengel4/auto.html#wiring
    -Mark
    E2 + E7 fan
    yeh i was using an ae82 loom for the rwd'ing conversion...
    problem is i need the coil to be on the RHS for the 2tg...ill have a gander at the site thoug
    nuts Grease Monkey
    auckland
    so are you running 2tg or 4ag?
    2t or 3t or 2tg coil is on r/h side.. 4age on l/h side which is not hard to move back to the r/h anyways.
    had a quick look at that site again and seems the diagrams have been removed
    haynes or toyota manuals are your friend. if i had a scanner i'd be able to help.
    toyota manual shows coil positive wire is connected straight to IG terminal on the ignition switch. no fuse or anything. the wire is black/yellow stripe (according to this manual). This wire likely comes out of the firewall behind the r/h strut tower around where the accelerator cable is.
    -Mark
    E2 + E7 fan
    im putting in a 2TG
    i took OUT the 4age that i had in it to put IN the 2TG
    ill have to take a look and see what wires are still there hanging...
    still need help with this...
    even if someone with a T18 can just expose the wiring going to the coil and then take some photos that would do the job...
    And done! It's the best I could do at work for the 10 min it took me to clean up the pic.
    Hope it helps
    <---click
    thanking you...
    now the fun part of actually reading it and putting it to use...haha
    all wired up and working mint now...cheers
    Haha, no worries. Glad to have helped!
  1. Needed! - RA63 Wiring Diagram
    By Spectre in forum Tech and Conversions
    Last Post: 06-09-2006, 10:54 AM
  2. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  3. i need a ST185GT4 wiring diagram or pinout
    By tai_180sx in forum Tech and Conversions
    Last Post: 17-02-2006, 12:27 PM
  4. AE111 Wiring Diagram
    By Steve-AE86 in forum Tech and Conversions
    Last Post: 28-12-2005, 09:57 PM
