Results 1 to 4 of 4
Thread: Aristo
    Junior Member Grease Monkey teamdrinkalot's Avatar
    Aug 2006
    Default Aristo
    When my son pulled the engine out of the half cut, he said that it had a hydraulic cooling fan. Does this run with oil? I do not have that hooked up as I have thermo fans, but that pump thing on the water pump is making a horrible squeal (like an electric motor). I am wondering if I need to loop the inlet and outlet and fill it with oil.
    Can someone share their knowledge!
    David
    vic
    Default Re: Aristo
    Yes loop the pipes and fill it with oil , May be too late tho
    Why the hell didnt you ditch that pump in favor of the normal JZA 80 supra water pump.
    It will be a fun job in the van
    Dave
    Aug 2006
    Default Re: Aristo
    I like to do things the hard way, ie: Get the motor in as soon as I can then spend the next 3 years sorting it out - then it is time for a new motor. Sort of similar to water torture.
    Lucky I am an enthusiast.
    Aug 2006
    Default Re: Aristo
    Thanks cambelt, I love this forum. Oil in and no more noise.
    1 issue at a time
  1. 2jz-gte aristo with reverse problems
    By Phantom83 in forum Tech and Conversions
    Last Post: 05-09-2008, 11:24 PM
