Results 1 to 9 of 9
Thread: MicroTech>X83 Tacho ??
    Junior Member Grease Monkey slydin-cressy-style's Avatar
    Default MicroTech>X83 Tacho ??
    Hi Guys
    Has anyone hooked up their Standard Mx83 Dash Tacho to the MicroTech ??
    I have an LTX12s wired into my Mx83 with 1JZ
    ATM my dash isnt hooked up and I've heard its not so easy
    Has anyone made it work ??
    Josh
    SUPPORTING AUSTRALIAN PERFORMANCE PRODUCTS...
    TURBOSMART MICROTECH JUST ALLOY RADIATORS
    THANKS TO:
    - ALL TRANSMISSIONS - IMPORT AUTO PARTS
    - P.I.T.S - PLATNIUM AUTO CARE
    Default Re: MicroTech>X83 Tacho ??
    Does the LTX12s have a tacho output?
    If it does, wire it up to the tacho.
    If it doesn't, you'll probably need to do one of those diode arrangements, from the coil -ve wire.
    I think that the Ltx12s has a Tacho in and out Correct me if Im wrong
    Is it that simple ??
    THANKS TO:
    If it has a tacho out, wire it up and see if it works.
    If it doesn't, you may need a tacho booster.
    Have a search through the Microtech Forums, see if there is any help there.
    Im having a look now Haha
    Again correct me if im wrong, According to the MicroTech website, They just have a Tacho output so maybe it is just a matter of hooking it up (famous last words)
    What about resistors etc ??
    THANKS TO:
    Nothing is needed if it works, but I'm not sure if the output on the Microtech, it may need a booster. In which case, have a search for the tacho booster thread, and build your own for $2.
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    i'm running a microtech lt10s on a 7mgte in an mx83. ended up using a tach booster to get mine working.
    Mike
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    I found the Tacho Booster thread
    http://www.toymods.net/forums/showthread.php?t=22574
    I roughly know how this thing works
    Has anyone else had success with Mx83 and Microtech ??
    THANKS TO:
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Yes you'll need a booster to get the tacho working. You can build your own or go buy one. MSD part number is 8920.
    1994 GZX90 Mark II 1GZ-FE V12
  1. Tacho tech
    By Hen in forum Tech and Conversions
    Last Post: 04-08-2009, 05:10 PM
  2. Tacho troubles
    By chrizer in forum Tech and Conversions
    Last Post: 13-06-2007, 10:39 AM
  3. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 10:36 AM
  4. RA40 tacho & aftermarket ECUs - anyone had trouble?
    Last Post: 29-11-2006, 04:59 PM
