Results 1 to 2 of 2
Thread: Causes of corrosion on body ground wires
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    Default Causes of corrosion on body ground wires
    I have an ST184 Celica which seems to be plagued with corrosion on many of the ground wires. At first I thought this was limited to the white furry deposits on the battery negative terminal (which i cleaned up and coated the terminal with WD40 to stop it recurring), but it appears to be more severe.
    I only really noticed this just now, my rear indicators became temperamental over the last few days and finally stopped working altogether. I pulled the bulbs out and noticed a big mess of white deposits and also a bit of rust on the bulb holders negative. Scratching all of this off made the indicators work for another half a day
    They stopped working again when I was out at a friends place and I really am quite partial to having indicators so I took them apart there again. On a whim I tested the impedance between adjacent ground wires (reverse bulb and indicator bulb) and found this was several K. As a quick fix I wrapped a wire around the indicator bulb and grounded this to the chassis which fixed the problem.
    I have also noticed the same rusty corrosion ocurring in the interior dome light and I have actually had to replace this unit as the last one completely fell apart as all the tracks had rusted away to nothing.
    I am starting to think that its not just the age of the car (1990 model) that is causing these issues and maybe there is something that I should be looking at. Looking forward to hearing what all you techies have to say about it
    Default Re: Causes of corrosion on body ground wires
    the furry stuff on battery terminal is often due to leaked acid.
    as for the rest of the car, maybe you live in a humid area? bare metal corrodes over time, and salt from sea breezes does not help.
  1. short stroke shock absorbers for AE86
    By roadsailing in forum Tech and Conversions
    Last Post: 17-01-2007, 03:11 PM
  2. TE-72 body parts swapping
    By arsenix in forum Tech and Conversions
    Last Post: 18-12-2005, 07:33 AM
