waste of time and effort, get some td04's from a wrx and fit them!
has anyone ever tried it ?
everyone says they dont fit , but what if ive made mine fit . what would the results be ?
i just need to source another front turbo exhaust housing , so i basically have 2 front turbos. and then im done .. ill add a pic of it all .. seriously it almost all bolts on !!
13.39sec @ 110.86mph.
265rwkw Supra (and climbing)
Originally Posted by MR 1JZ
Almost bolts on, and at the same time really doesn't!
Go for a drive in a 2JZGTE in parallel turbo mode... it's pretty laggy... an extra 500cc less won't help
Btw it has been done as well...
yea i been in a aristo in parallel mode .. but thats auto and a barge tank .
the jzx90 is manual and 200kg lighter.
how laggy we talking ? like spool after 3500-4k rpm ..
cause i got a gt30 setup in the forsale section , but im trying to cut corners to get house loan . the 2jz twins wouldnt even ow $500 by time its complete all the oil water lines shouldnt take much work to fit .. as you see in pics it just a set of custom dumps which i have to make.
Oil lines fit?
It'll be laggier than a 2JZ that is for sure
mine in parallel got full boost at 4k nothing below 3.
Glenn
Current Ride http://www.toymods.net/forums/showthread.php?t=41123
Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
I had twin 2JZ turbos on my car before I sold it, with a custom manifold to fit it all together, it was damn laggy but went like the clappers. Still nowhere near as good as a GT3076R etc though. Not worth the effort for little result.
244rwkw / 328hp @ 18psi
