Results 1 to 11 of 11
Thread: Smoking problem valve seals
    Junior Member 1st year Apprentice lee3671987's Avatar
    Jun 2008
    Default Smoking problem valve seals
    Hi
    My camry blows a white smoke during idle.
    Might be the valve stem seals. I'd like to give it a try fixing it my self but i better not (incase somthing went wrong). Plus i dont have the tools and the knowledge.
    any workshop specialised in these area? like in wa
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default Re: Smoking problem valve seals
    Valve stems usually only blow oil smoke on startup due to oil running down the valve into the cylinder. They don't usually blow smoke constantly at idle.
    Jun 2008
    it does it randomly, sometimes doesnt smoke at all.
    its smell like burnt oil and its actually blue smoke if u look at from a distance.
    rings gone?
    RA23 - Twincharged
    JZZ20 - Daily
    take a spark plug out if the thread has oil in it then your seals are in need of replacing also how many k's on the car/motor
    check all the plugs i mean
    Jun 2008
    jus got the mechanic checked today and he said definetly the seals needs replacement.
    also got a quote and gonna cost over 2k
    Jun 2008
    rings gone......
    how to fix that?
    do i have to get a whole new pistons or just changing the ring it self is enough??
    Quote Originally Posted by Gavatron
    i thought if that was really bad you will get smoke at idle too.
    i remember some phag in fastfours asking martin donnon a questions about buckets or shims or something and martin donnon said the easy way for him to do it was to leave out the stem seals and that means you will get white smoke at start and when idling.
    and martin donnon said that so it must be true.
    new rings and a dunnybrush of the bores.
    whether or not it needs pistons cant be seen until u strip the motor...
    Tallahassee, FL USofA
    Quote Originally Posted by lee3671987
    Just drive it.
    Is it using a lot of oil, km/mi per l? Overheating? Did it start smoking suddenly and also lose power?
    What's the compression?
    If it isn't using more oil then it would cost to fix and if it is just gradual wear & not a broken ring/piston, then it might run 10,000+ without getting much worse.
  2. 1JZ-GTE valve stem seals
    By rogue-vl in forum Tech and Conversions
    Last Post: 17-05-2010, 02:28 PM
  3. 20 valve Problem. ST
    By Jorrs in forum Tech and Conversions
    Last Post: 27-03-2007, 04:55 PM
  4. 2TG valve guides
    Last Post: 24-10-2006, 10:43 AM
  5. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
