Results 1 to 8 of 8
Thread: What box for 7M or 5M
    Junior Member Backyard Mechanic Hokey's Avatar
    Default What box for 7M or 5M
    G'day,
    just wondering if anyone knows whether a box out of a older 4 runner will bolt up to a 7MGE or a 5M or anyother M variatn for that matter. i think the gearbox may be R151. so would a bellhousing from an MA70 work?
    Default Re: What box for 7M or 5M
    If the 4runner has an R151 gearbox then to my knowledge a 7M-GTE -> R154 bellhousing will NOT just fit and work. (R151 has a longer inputshaft).
    If the 4runner has a G5X gearbox then a 5M-E, 7M-GE -> W58 bellhousing should work to my knowledge.
    thankyou very much wilbo
    Hmm, wait a sec on that actually!!!!
    Have a search for "Skip" in the old Toymods, I recall something about the 4wd R series gearbox having a longer input shaft as opposed to R154's...!!!!!!
    i should prob just ask him hey. he is on the other 4wd forum aswell.
    Quote Originally Posted by skip
    The conversion: It was reasonably difficult but there is alot harder ones out there Smile To begin with I sourced a bellhousing, clutch slave, fork, pushrod, pivot ball and through out bearing carrier from Dellow. The R154/JZ bellhousing would have bolted up but the R154 has a 190mm input shaft compared to the 160mm R151f so it wouldnt have worked. I then got a billet steel flywheel made up and a full face organic clutch which quickly died, I now have a 9 puck ceramic clutch with upgraded clamp force.
    http://forums.toymods.org.au/index.p...t=0#msg_813497
    hmm ok. i might have to tell the bloke his conversion might be a bit harder.
    Cheers, Wilbo
    Could you use a 7M/R154 housing and a 30mm spacer?
  1. 6M and 7M differences???
    By fatboy13 in forum Tech and Conversions
    Last Post: 10-01-2006, 07:20 PM
  2. to 7m or 1jz
    By EMD-MX83 in forum Tech and Conversions
    Last Post: 29-11-2005, 09:56 AM
