Results 1 to 4 of 4
Thread: 18RG in TA23
    Mar 2017
    Default 18RG in TA23
    Hi Guys,
    20 years ago I had an RA23 with an 18RGR. Recently I bought a TA23 in unmodified condition.
    It currently has the 2TC. I'd like to get another 18rg.
    In the RA23 it was pretty much a bolt in job. Just had to use sump and oil pump from the 18rc.
    My question is will an 18rg bolt straight into a TA23 like it does in the RA?
    I realise the engine cross member is different. If I can source an RA23 one will it bolt in and match up to the TA23 gearbox?
    Any other considerations with this conversion?
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Default Re: 18RG in TA23
    You will need a w50 from and ra23/ra28/rt104 and an ra23/ra28 crossmember, or you could keep the front sump crossmember and use a sump from an rt104 as they are front sump. sounds like a decent proposition, a 3sge beams would cost about the same rebuilding an 18rg so unless you already have a good condition 18rg i'd steer towards a fitting a beams
    Cheers, Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
    Mar 2017
    Thanks Peter.
    Will the T50 gearbox crossmember fit the W50 or do I need to get an RA23 as well?
    Greg
    Hi Greg,
    I am pretty sure the T50 gearbox crossmember is vastly different to the W50 gearbox Crossmember.
    If you want, i have both and engine and gearbox crossmember from an RA23 that you can use - and would be happy to buy your TA23 items.
    ...... butt scratcher?!
  1. Electronic PDF Celica ra28 ta23 18RG parts catalogue
    By auto351 in forum Tech and Conversions
    Last Post: 15-06-2015, 06:21 AM
  2. KE20 with 18rg + TA23
    By Night Rider-TA23 in forum Tech and Conversions
    Last Post: 06-09-2007, 01:19 PM
  3. 1JZ in to a TA23!!
    By 'ol_skool_'75 in forum Engine & Driveline Conversions
    Last Post: 09-02-2007, 06:27 PM
  4. 2jz into Ta23
    By Rusty in forum Tech and Conversions
    Last Post: 24-12-2006, 07:30 PM
