bugger, this is still happening??
If its still not starting and your definitely getting spark then I would check things in the following order
Vacuum leaks (cant hurt, even though uve probably done it a hundred times)
inside of dizzy cap for cracks or lines to show shorting
all sensors are connected properly, and check continuity of all wires back to ECU loom connector
fuel pump operation - shorting b+ terminal to another pin (cant remember which sorry) with Ignition on, then feel return hose
injector operation
get ECU swapped/tested
This is all assuming there isnt some immobilser or kill switch stuffing up the mix, but they usually immobilise at coil or alt.
