Page 7 of 7 FirstFirst ... 567
Results 91 to 99 of 99
Thread: 1g-gte misfiring on first few seconds of startup - common?
  1. #91
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Default Re: 1g-gte misfiring on first few seconds of startup - common?
    Sleepy1G, if you were to turn the key and wait 5 seconds before cranking do you still get the problem ?
    Just thinking out a loud
    “if you are losing pressure over night, then the fuel line pressure would return very quickly once the fuel pump is started & well before the engine sparks up,
    If there is no fuel pressure then the engine will not start so this indicated there must be fuel pressure”
  2. #92
    Jul 2009
    pressure is there within a second or 2,
    i'm wondering if there maybe a glitch in the map for the cold start. wonder if it more on a particular variant of the 1g
    1985 RT142, 1GGTE,.now with t67-25g
    2009 Ford Fiesta LX
    1970 Ford Cortina MK2 440
  3. #93
    Nov 2007
    if there would be a glitch on the cold starts for the map, wouldn't all 1g-gte's of a certain generation do it then?
  4. #94
    Nov 2007
    N.S.W
    I too don’t think it’s a glitch in the maps (the ECU only uses the maps for fuel correction as I understand it) and this would be evident from the factory, it may however be older capacitors which are showing there age and leaking.
    but from what I have read we have still not ruled out the fact that fuel is leaking out of the system (via the injectors?) this causing air/vapor lock and this would take time to flush out, even with fuel pressure when the air/viper hits the injector it would cause a loss of fuel for a short time.
    I think even if we loss pressure over night as long as there is fuel (only) in the lines once the key turned fuel pressure & supply is restored instantly.
  5. #95
    Nov 2007
    Yeah that's what I've been told, pressure will drop but as long as there is fuel remaining in the lines it shouldn't be a problem. If a fuel pump check valve was bad i'd assume fuel would leak back into the tank and cause a bad start.
    Other than that I'd agree with the dirty injectors causing fuel to leak into the inlet tract.
  6. #96
    Nov 2007
    N.S.W
    are you planing on getting the injectors checked & serviced ?
  7. #97
    Nov 2007
    Yes I am....
  8. #98
    Nov 2007
    About a week ago I changed the Spark plugs from NGK BCPR6ES to Denso PQ20R's that I had from my old soarer, since then it has been starting better, but only sometimes, other times the same problem.
    Wondering if a fuel pressure reg could cause this.
    Looks like I'll be replacing the fuel pressure reg next.
    Thanks.
  9. #99
    Nov 2007
    I have since changed the fuel filter, not sure if that has anything to do with it but it didn't help.
    Been looking for a fuel pressure reg, as I sold my old one with the rail. Does anybody have one?
    Other than that the only other thing i could do is get the injectors cleaned.
  1. Common Problem AE71/KE70 (Now with pics) Headlight/indicator Switch
    By stahlz_ae86 in forum Tech and Conversions
    Last Post: 18-07-2006, 05:13 PM
