pressure is there within a second or 2,
i'm wondering if there maybe a glitch in the map for the cold start. wonder if it more on a particular variant of the 1g
Sleepy1G, if you were to turn the key and wait 5 seconds before cranking do you still get the problem ?
Just thinking out a loud
“if you are losing pressure over night, then the fuel line pressure would return very quickly once the fuel pump is started & well before the engine sparks up,
If there is no fuel pressure then the engine will not start so this indicated there must be fuel pressure”
1985 RT142, 1GGTE,.now with t67-25g
2009 Ford Fiesta LX
1970 Ford Cortina MK2 440
if there would be a glitch on the cold starts for the map, wouldn't all 1g-gte's of a certain generation do it then?
I too don’t think it’s a glitch in the maps (the ECU only uses the maps for fuel correction as I understand it) and this would be evident from the factory, it may however be older capacitors which are showing there age and leaking.
but from what I have read we have still not ruled out the fact that fuel is leaking out of the system (via the injectors?) this causing air/vapor lock and this would take time to flush out, even with fuel pressure when the air/viper hits the injector it would cause a loss of fuel for a short time.
I think even if we loss pressure over night as long as there is fuel (only) in the lines once the key turned fuel pressure & supply is restored instantly.
Yeah that's what I've been told, pressure will drop but as long as there is fuel remaining in the lines it shouldn't be a problem. If a fuel pump check valve was bad i'd assume fuel would leak back into the tank and cause a bad start.
Other than that I'd agree with the dirty injectors causing fuel to leak into the inlet tract.
are you planing on getting the injectors checked & serviced ?
Yes I am....
About a week ago I changed the Spark plugs from NGK BCPR6ES to Denso PQ20R's that I had from my old soarer, since then it has been starting better, but only sometimes, other times the same problem.
Wondering if a fuel pressure reg could cause this.
Looks like I'll be replacing the fuel pressure reg next.
Thanks.
I have since changed the fuel filter, not sure if that has anything to do with it but it didn't help.
Been looking for a fuel pressure reg, as I sold my old one with the rail. Does anybody have one?
Other than that the only other thing i could do is get the injectors cleaned.
