Page 9 of 34 FirstFirst ... 789101119 ... LastLast
Results 121 to 135 of 496
  1. #121
    Jun 2008
    Yep, have to agree.
    Nothing beats a good solid electrical connection.
    Inductive chargers can stay with leccy toothbrushes thanks ;p
  2. #122
    Gone from 005 to XR5! Automotive Encyclopaedia Matty P's Avatar
    They had an electric car challenge on Aussie Top Gear last night.
    One did a Kingswood with a big electric motor like yours. The other was a Mighty Boy ute powered by 4 cordless drills.
    Guess which one worked better
  3. #123
    Quote Originally Posted by Matty P
    At least the one with the electric drills has the ability to let the driver use part of the motor to repair the car if it breaks down.
    (Which it did, quite a lot)
    www.billzilla.org
    Toymods founding member #3
  4. #124
    Quote Originally Posted by MWP
    The inductive charge paddle used on the EV1 has nothing to do with "fast charging".
    Its just a way of making a connection without electrical contacts.
    The paddles are water, moisture, dust, etc proof which is why they are used.
    An actual cable can move more current if required with less transmission los
    Think about an electric toothbrush
  5. #125
    Chiba
    Ah, my mistake. I assumed regen.
    For overnight recharging, I would go for a dedicated 15Amp, or even 20Amp circuit for the charger. Drive in, park the car and plug it in.
    If your switchboard is in or on the garage wall, it will be relatively cheap to have a power outlet installed close by.
  6. #126
    Jun 2008
    15A plug already wired up
    Ol'man is a electrician which is handy.
    Also have 3Phase power available for fast charger, maybe later down the track...
    Currently planning to have the charger on-board with a extension lead handy, The charge rate can be ramped down for conventional 10A outlets too.
    -A
  7. #127
    Chiba
    Sweet. Always handy to have an electrician around.
  8. #128
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Is there a formula or rule of thumb where you can assess an electric motor (DC or AC) plus its number/capacity/rating of batteries, and the gearing (via a transmission or direct drive?) and determine what this is equivilent to in terms of ICE power and torque? I would like to know technicaly what makes the Tesla different to most EV conversions with have 0-100km/h in 10 seconds and 50 - 80km range only (besides cost)? Thanks.
    RA23
    1G-GZE
  9. #129
    Jun 2008
    Tesla Wipes the floor with everyone because...
    A. Super efficient 3phase motor & controller package, designed specifically for the job.
    B. Batteries
    C. Batteries
  10. #130
    Quote Originally Posted by VA61DETT
    B. Batteries
    C. Batteries
    You forgot to mention the batteries.....
  11. #131
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Not to mention the materials that are used to build the car, it's designed to be an electrical car from the ground up, not a conversion.
  12. #132
    WA (Perth)
    Yes, an overall weight of 1240kg, a 185Kw / 375Nm engine weighing 52kg and a 450kg battery pack combining to give 0-60mph in 4 seconds and a range of 350km. Nice.
    RA23
    1G-GZE
  13. #133
    Jul 2007
    how is this coming along now?
  14. #134
    Quote Originally Posted by greywolf
    Doesnt the Tesla share a lot of its chasis with the Lotus Elise?
  15. #135
    Nsw
    Nope, brand new chassis designed around Lotus Elise chassis development technology.
    Got that from Wikipedia.
    EDIT : Again from Wikipedia, apparently it shares less than 10% of it's componets with Lotus vehicles, just minor stuff. It is manufactered at the Lotus factory though.
    Last Post: 08-01-2006, 01:27 AM
