have you thought about getting your car into something like New Scientist or similar academic journal? http://www.newscientist.com/article/...commuting.html
I have just read this whole thread.. omg alot of time and effort must have gone into this!
ill be looking out for it.. i read somewhere in here you are in midland? im just up in swan view.. so if i see you round expect a wave haha!
well done and good luck for the w/e
Did you end up testing it out?
How did it go?
Update
Monday, 2 November 2009
She runs!
http://www.youtube.com/watch?v=Rp3mTNzVyWM
Only had a couple of small hiccups, I found that my old 5M TPS was not returning to the ‘idle’ position reliably, the resistance was not dropping below the 150R level so the controller would not start.
I ended up rigging a 5K pot for test, (now on the hunt for a new TPS *hint*hint*).
Once I got it to spin up the bloody power steering pump proceeded to leak fluid from the top banjo fitting.
Under closer inspection I found the fitting was warped and ended up filing it down to get a good seal (after several attempts & much leaked fluid)..bloody thing.
There is a bit of a concerning vibration from the motor, possibly the flywheel may be out of balance, this will require further inspection…later…
All in all, everything worked & nothing was ruined, now to get the dash back in!
-A
Four Cam Inside The VG30DET+T powered MA61.. actually running, really it is!, no wait its broken again...
The Lithium Ion Powered Sera EV Conversion, Getting some upgrade love.
Latest member: The AW11 MR2 'Trouble'
280ZX Now with RD28 Turbo conversion. Actaully finished!
Nice work dood!
but, skid vids seem to be missing![]()
Cool! Dare I ask how much this has cost you to date?
Hydra
JZA61 Celica XX
I have read about doing thing before, it looks like a really interesting project! Great Work!
I'm with Hydra, any ideas on roughly how much its cost you?
I secretly want to do this with an old corolla - oh wait, it's no longer a secret!
Hydra
JZA61 Celica XX
fantastic news! just needs some garage skid pics?
re: power steer pump - get some new copper washers to go either side of the banjo fitting?
query: how substantial is the end-play control on the motor drive-shaft? is the motor output designed for a direct coupling (like yours) or an offset pulley arrangement?
Cheers PPL
Conversion cost is getting close to 20K (over half is in the batteries alone!)
-thechuckster
What do you mean by 'end play control' ?
The motor just runs 2 big roller bearing races as far as I can see, there is no thrust bearing assy of any kind. They have been extensively used on many electric vehicle conversions in clutch, direct drive, series (custom shafts) & parallel (S/C belt drive) set-ups.
The bloody pump was actually a problem with the banjo fitting itself, swapped in 2 sets of washers, still pissed fluid everywhere, 'tis all good now.
-A
'end play control' - as is something acting as a thrust washer as usually found midway along a crankshaft.
I was just thinking about it as i thought the motor came with a keyway at the drive end (to suit locking a pulley onto the shaft) rather than a drive plate/flange that you'd attach a flexible coupling or flywheel to.
but as you say the motor is designed for this job.
btw: skid pics still not loading?
any updates?
it must have been driven by now?
hello
No not yet, still working on it!!!
Really nice.
wow! this is 1 hectic work! i cant wait to see the final product mate.
thumbs up for you and your idea!
