Page 20 of 34 FirstFirst ... 10181920212230 ... LastLast
Results 286 to 300 of 496
  1. #286
    Jul 2009
    I have just read this whole thread.. omg alot of time and effort must have gone into this!
    ill be looking out for it.. i read somewhere in here you are in midland? im just up in swan view.. so if i see you round expect a wave haha!
    well done and good luck for the w/e
  2. #287
    have you thought about getting your car into something like New Scientist or similar academic journal? http://www.newscientist.com/article/...commuting.html
  3. #288
    Jul 2009
    Did you end up testing it out?
    How did it go?
  4. #289
    Jun 2008
    Smile Toyota Sera EV Conversion RUNS!!!!!.. somewhat
    Update
    Monday, 2 November 2009
    She runs!
    http://www.youtube.com/watch?v=Rp3mTNzVyWM
    Only had a couple of small hiccups, I found that my old 5M TPS was not returning to the ‘idle’ position reliably, the resistance was not dropping below the 150R level so the controller would not start.
    I ended up rigging a 5K pot for test, (now on the hunt for a new TPS *hint*hint*).
    Once I got it to spin up the bloody power steering pump proceeded to leak fluid from the top banjo fitting.
    Under closer inspection I found the fitting was warped and ended up filing it down to get a good seal (after several attempts & much leaked fluid)..bloody thing.
    There is a bit of a concerning vibration from the motor, possibly the flywheel may be out of balance, this will require further inspection…later…
    All in all, everything worked & nothing was ruined, now to get the dash back in!
    -A
  5. #290
    Nice work dood!
    but, skid vids seem to be missing
  6. #291
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Cool! Dare I ask how much this has cost you to date?
  7. #292
    Nov 2007
    I have read about doing thing before, it looks like a really interesting project! Great Work!
    I'm with Hydra, any ideas on roughly how much its cost you?
  8. #293
    I secretly want to do this with an old corolla - oh wait, it's no longer a secret!
  9. #294
    fantastic news! just needs some garage skid pics?
    re: power steer pump - get some new copper washers to go either side of the banjo fitting?
    query: how substantial is the end-play control on the motor drive-shaft? is the motor output designed for a direct coupling (like yours) or an offset pulley arrangement?
  10. #295
    Jun 2008
    Cheers PPL
    Conversion cost is getting close to 20K (over half is in the batteries alone!)
    -thechuckster
    What do you mean by 'end play control' ?
    The motor just runs 2 big roller bearing races as far as I can see, there is no thrust bearing assy of any kind. They have been extensively used on many electric vehicle conversions in clutch, direct drive, series (custom shafts) & parallel (S/C belt drive) set-ups.
    The bloody pump was actually a problem with the banjo fitting itself, swapped in 2 sets of washers, still pissed fluid everywhere, 'tis all good now.
    -A
  11. #296
    'end play control' - as is something acting as a thrust washer as usually found midway along a crankshaft.
    I was just thinking about it as i thought the motor came with a keyway at the drive end (to suit locking a pulley onto the shaft) rather than a drive plate/flange that you'd attach a flexible coupling or flywheel to.
    but as you say the motor is designed for this job.
    btw: skid pics still not loading?
  12. #297
    User Conversion King
    NWA
    any updates?
    it must have been driven by now?
    hello
  13. #298
    Jun 2008
    No not yet, still working on it!!!
  14. #299
    Supra since '86 Backyard Mechanic rsdeo's Avatar
    Burlington Ontario, Canada
    Really nice.
  15. #300
    Nov 2009
    wow! this is 1 hectic work! i cant wait to see the final product mate.
    thumbs up for you and your idea!
    Last Post: 08-01-2006, 12:27 AM
