Page 3 of 10 FirstFirst 12345 ... LastLast
Results 31 to 45 of 143
Thread: HSD coilover sleeve kits 45mm 48mm 51mm 55mm now available only $299
    Junior Member Domestic Engineer TA22 GT's Avatar
    Default Re: HSD coilover sleeve kits only $299
    I'm pretty sure the XT130 struts are 2 inch or 50.8mm
    Simon
    The internal diameter of mine definitely measure 51mm with a ruler and eye, so can't see that there'd be an issue. The quality of the sleeves is quite good in my opinion.
    Are the lock nuts also made from steel or are they alloy?
    Simon
    Lock nuts are alloy. I haven't seen many where the lock nuts aren't, but maybe there's some.
    Quote Originally Posted by GeneSPIDA
    OK thanks. Do you have a set of these in your TA22? Interested in what you think of the springs eg4 or 5kg?
    Simon
    I haven't fitted them yet, but have a set of 4kg and 5kg springs. Planning to use the 5kg ones, but will switch to the lower rate ones if too harsh.
    I'm going 6kg in the front, and 4kg in the rear, if that helps...
    ([][][]II--LT--II[][][])
  8. #38
    Quote Originally Posted by twentyEight
    Thanks guys. Have you tried the 5kg on the front? Or are you just thinking 6kg will be better for you?
    Simon
  9. #39
    How did I miss this !
    $299 is a dead set fucking Bargain !
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  10. #40
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Hi Rod, you know it and judging by the sales, so do Toymoders.
    Quote Originally Posted by TheToyman75
  11. #41
    Apart from the value, I guess it's cos none of us old Toyota owners have bolt in options. DIY all the way!
    Can't wait for mine to come
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  12. #42
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    the same way i did! and yes they are a fU(#ing bargain. what's the postage to 2601 for 5kg/mm in 51mm?
  13. #43
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    Very interesting. Postage cost to 4130?
    Cheers!
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
  14. #44
    freight to 2601 will be $15.
    Quote Originally Posted by ta23-mbzq-nnr
  15. #45
    Freight to 4130 will be $15 also.
    Quote Originally Posted by Major Clod
    Cheers!
  1. Coilover sleeve and strut welding info needed
    Last Post: 02-09-2012, 09:57 AM
  2. Thoughts on sleeve coilover kits (MA61)
    By VA61DETT in forum Tech and Conversions
    Last Post: 18-12-2008, 06:55 PM
  3. Coilover sleeve kits, what's the go?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 27-07-2008, 10:36 PM
  4. coilover sleeve lenght?
    By slide86 in forum Tech and Conversions
    Last Post: 18-01-2006, 07:18 AM
