Results 1 to 4 of 4
Thread: Toyota Aristo front brake specs
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Default Toyota Aristo front brake specs
    hi guys, does anyone know if DBA or RDA offer replacement front brake rotors to suit the Aristo JZS147.
    Default Re: Toyota Aristo front brake specs
    Only just saw this request but here's the info if anyone is interested:
    DBA
    DBA4748 SL / SR
    296mm diameter
    51mm height
    32mm thickness
    62mm centrehole
    RDA
    Get the ones for JZA80TT
    323mm dia
    50mm height
    30mm thickness
    62mm centrehole
    Peter
    Jun 2008
    I'm 99% sure they are the same as TT Soarers jzz30, I have a set of both in the work shop, I will check tomorrow and let you know.
    Current Builds
    Soarer Built 1.5jz 425rwkws
    1JZ LPG Build, so far 204rwkw@10psi
    Quote Originally Posted by infotechplus
    RDA
    323mm dia
    50mm height
    30mm thickness
    62mm centrehole
    Peter
    These wont be much use to him without the JZA80 calipers (im assuming he only wants new rotors here)
    And yeah the stock Aristo brakes are the same as JZZ30/ non big brake JZA80 and are standard items from either DBA or RDA
    By The Witzl in forum FAQ
  2. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 12:58 PM
