Results 16 to 21 of 21
Thread: JZA80 SZ to 1JZ-GTE from a Supra
    Default Re: JZA80 SZ to 1JZ-GTE from a Supra
    Sure you wouldn't "need" the sump but it already has an oil drain which he will need, saves having to modify a different sump.
    And yes they'd be tiny turbo's for a 3L but they'd still flow as much air as they will on a 2.5.
    Junior Member 1st year Apprentice ark_112's Avatar
    Apr 2008
    Tasmania
    But its not just a simple case of unbolt from the 1j and bolt onto the 2j?
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    wont putting the 1jz-gte head on the 2jz-GE block be the same risk as doing a NA-T conversion? and limited to 7psi?
    pretty sure ark has plans for big single/power in the future
    87' z20 Soarer - 1jz Gt35r -
    Apr 2008
    Tasmania
    yea. I do want to go for a big single later on
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    the 1.5jz would be good if your looking for a project on a budget
    the stock bottom end will hold up to 400kw or so before any major issues..
    the main difference between 2jzgte and ge is piston and oil squirters
    ive read tho that in high hp motors they remove the squiters anyways..
    we'll have to catch up for some drinks mate and discuss this in more depth
    Apr 2008
    Tasmania
    Sounds good.
    I think I would still have to get it engineered. I am starting a new job next week so I think I will be able to afford an RZ if I can sell my SZ for around $12k - $15k so i might just look at doing that instead.
