Yeah thats the body.
Will get total length tonight.
Thanks dude.
Brad
thats the body?
if you fully extend or fully compress the shock rod, what is total length?
i forgot to measure last night.. will measure tonight if i get home in time
Thanks dude.
Brad
1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
1994 Ford Falcon Pedovan - Rape Dungeon
I looked into coilovers for my 35, got told Bilsteins would cost NZ$2000. What exactly do you get for your money? Pics perhaps?
1985 KP60 Starlet - Sold
1978 KE35 SR
Dave just told me he found some KYB's he slapped in them.
OC - Still wouldn't mind those Koni's. Didn't get a chance to measure them.
Brad
Koni Red adjustable
82P-1743
802
"special D"
length, from the built in spacer at the bottom to where the built in threaded bit will sti at the top of strut tube = 415mm
without the built in top ring (other shocks use a seperate but and spacer at the top) it is 390 long
diameter = 40mm
what is the internal diamerter and length of the strut tube?
fully compressed length From spacer bit at bottom top the top of threaded rod = about 470mm
fully extended length = 660mm
these guys used same ones http://te51levin.superjamie.net/hrm2.html
and they look liekthese
(i won't be home when auction finishesbut they are cheap atm, not so cheap buy now)
(edit: Buy now = AUD$310 to aus)
they say
KONI品番82P-1743
■KE20、KE25、TE21、22、25、「セダン、クーペ1200,1400、1600(レビン、ト レノ、除く)」
■KE3、4、5、6、(1200、1300、セダン、クーペ)
■筒径39,8mm筒長420mm、ストローク最大235mm最小ストローク45mm、
thats, diameter... stroke (rod when fully out), stroke (rod when fully in)
they also weigh abotu 5-5.5kg, for postage![]()
btw, i now have a spare set![]()
ke70 struts arn't 2inch I/D are they the same internal diameter as ke35? because i'm sure i've seen koni yellows pop up on forums from time to time for sale for ke70 struts.
Nah they are 1 and 3 quarters, I learnt that the hard way.
Brad
