Results 46 to 52 of 52
Thread: aluminium exhaust, a good idea?
  1. #46
    Default Re: aluminium exhaust, a good idea?
    shhhh
    as far as heat goes, aluminium oxide is almost a black body for radiation (as are many oxides) so what heat goes in one side, just come out the other side....
    so if you had a thin oxide sheet, and it was close enough to actually be heated, then you could sort of diffusely "see through" it, but it would be more like a primitive Predator camo suit, where what goes in one side gets sent out other side...
  2. #47
    I know what wombat means,
    I had a turbo that you could swear you could see the gasses flowing along the manifold runners & trough the turbo when it was extremely hot after a high speed freeway run late at night. I used to pull off the highway quickly and open the bonnet to show people the 'glowing light show' that was my turbocharger Perhaps just radiant heat, but I do know what he means as I have seen it also. ..err whatever it was I saw...
    Or was it those funny little pills I popped beforehand..........?
  3. #48
    A thin layer of hot air can be reflective. Like when you drive on a country road on a hot summers day and you look ahead at the road on the horizon and it appears to either be wet or like a mirror is laid flat on the road.
    This thin layer of hot air on the surface is a low density, low refractive index layer that acts like a mirror through a process known as total internal reflection.
    It may be that the hot air sorrounding hot turbo housings may be acting as a reflector in a similar way.
  4. #49
    vic
    I remember many years ago pasing a truck with a holden six going up the wesgate bridge and could see thru the glowing manifold at all the exhaust gases coming out the ports . Nearly crashed in the process lol
    Dave
  5. #50
    Nov 2007
    it will just melt and calaps lol
  6. #51
    Are you on crack? This thread is 3 months old, and then all you add is a small piece of meaningless dribble.
    Add that to the further dribble in LadySX's thread, and you just scored some rep my man.... and not of the positive kind.
  7. #52
    Heh that's the lowest rep I've ever seen here. lolz ....
    www.billzilla.org
    Toymods founding member #3
  1. 1JZ-GTE vs 2JZ-GTE JDM Cam Profiles
    Last Post: 23-11-2007, 05:35 PM
