Results 16 to 19 of 19
Thread: suspension help "balljoint spacers"
    Default Re: suspension help "balljoint spacers"
    the poitn is, that the REAL LCA goes between the inner pivot point, and the ball joint pivot.
    if you don't move the inner pivot up, or the ball joint down, all you are doing is making the LCA "curved" with no effect on the roll centre at all.
    ie, putting spacer between balljoint and LCA has no effect. at all.
    to have an effect you MUST move the ball joint pivot down, which is the point of putting in an RCA
    edit:
    the spacer in GT's diagram will add a small amount of track and camber, but should not affect the roll centre.
    (it might help with anti-rollbar clearance perhaps?)
    By the way, that's in an ae92, but that's not factory balljoint, and the upright doesn't look too familiar either for that matter.
    Toymods Club Member
    Quote Originally Posted by -GT-
    That looks a lot like the rear upright in an AW11. They use a flanged balljoint, so a spacer between the the upright flange and the BJ flange would have achieved the same thing.
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    Spot on - a RCA goes between balljoint and wheel hub centre. That's ABOVE the lower balljoint, not below.
    '73 TA12 Carina - pushrod power project
    '77 TA14 Carina - 1GGTE swap in the works
    '77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
  1. Trailing arm rear suspension pros/cons?
    By Brett in forum Tech and Conversions
    Last Post: 02-06-2008, 04:48 PM
  2. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  3. Replies: 8
    Last Post: 09-09-2006, 11:32 AM
  4. Your suspension & you...
    Last Post: 23-05-2006, 08:41 AM
