Results 16 to 30 of 51
Thread: 1JZ Smoke badness.
    Carbon neutral Carport Converter Jt_70R's Avatar
    Default Re: 1JZ Smoke badness.
    One would think if you overfilled the oil, it would blow smoke the whole time, not randomly or intermittently. But it is a possibility.
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Car has been fine the last 2 days, I will see how it goes.
    Im giving it a bit as well, to try and ensure that it isnt anything wrong, and will be doing another oil change (With the correct amount of oil) again tonight or tomorrow.
    I have a Dyno on Saturday, so if there is anything wrong, I'm sure it will come up there.
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    Is a Self Employed Grease Monkey wombat's Avatar
    After reading your first post. The important line was "I did an oil change on the weekend," My first thought then was too much oil. Had it happen at work before. One of the guys filled the oil in an astra twice, so literally double the amount of oil. we managed to drive it for easy 5 mins without anything, then it poured white smoke out of the exhaust as we went around a roundabout. Then once we straightened up again it stopped.
    So it won't blow smoke all the time.
    He also said he was "cruising down the expressway" when it happened tho, so doubt much oil would be sloshing around.
    Herus, hopefully for you it is just an excessive oil issue!
    Feb 2007
    It was on the hill bit, so could have happened then. I may have just accelerated to overtake someone as well.
    LOL you put too much oil in?
    By how much is too much?
    Tallahassee, FL USofA
    An extra quart in my 4AGE put out smoke like a mosquito fogging truck for a few days, whenever the engine was tilted towards the shallow end of the pan.
    I didn't think it was over fillled enough to bother with draining it.
    Feb 2007
    I ended up taking out about 750ml
    Seems OK.
    Least I dont seem to be the only person thats done it recently. (Hey Ed )
    Feb 2007
    Updates!
    Well after having no problems with a lower level of oil, and then doing an oil change, and still having no issues for ~100klms, I went on my first dyno run..
    The car was fine, boosted no worries had no issues at all with my 3 runs.
    Was talking to the dyno operator, and suddenly, white smoke, bad fuel smell again.
    It was instant, we had been standing outside the car for ~ 1 minutes before it started again.
    The dyno operator suggested it may be my fuel pressure regulator not function correctly, but Im beginning to think it may be ECU related as Z2TT said.
    Do we have any other suggestions before I spend lots of money trying to get the problem fixed?
    Oh, BTW, I hit 140rwkw with a stock 1jz with no mods, and still running the restrictive cressida exhaust. Dyno graph will be in my members ride thread shortly.
    Thanks guys.
    Herus
    Her-ass, does the 1JZ have a PCV valve or such like in the breathers in the cam cover? this could be blocked/not functioning correctly. We did a swap on a mate of mines EP82 and it billowed smoke out the back until we correctly setup the PCV system.
    RA23 - Twincharged
    JZZ20 - Daily
    was it at idle when this happened?
    Feb 2007
    Kedderz, yes it does, Ill check it now.
    Wombat, yes it was at Idle when this happened.
    Feb 2007
    PCV is clean appears to work fine.
    Aug 2006
    Have you opened the ecu up for a look. Heard many a story of similer things happening from caps in the ecu. Sounds like injector sticking or injector firing issues.
    My bet is the ecu, esp as it comes and goes like it is. Have you checked for codes?
    Feb 2007
    Havent checked for codes yet, will do it tomorrow if I get time.
    The ECU will hopefully come out tomorrow as well for an inspection.
  1. Whoops ... 1JZ turbo blown?
    By BabyZ in forum Tech and Conversions
    Last Post: 09-12-2007, 08:21 AM
  2. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
