so can i upgrade to r31 axles ?
rt142 live axle is borgwarner, ra60 is t-series (similar thickness shafts)
they'd both break with a 1jz![]()
i'd rather an lsd as its less prone to snap oversteer.
Destroyer of 'Drop Forged' spanners
nope (if they did fit there'd be no point in upgrading)
why is that ?
what upgrade would you suggest ?
i looked into doin this it works but sence i dont have the power i didnt do it
but since you have a 1jz put a hilux diff in it
they are unbreakable
i cant remember what year
it does work tho
I find it difficult to belive that r31 axels being 28 spline diff would fit into a rt141 for numerous reasons. The r31 diff is wider so it is unlikely that the axles would be the same length. The r31 bearings are larger so I dobut they would go in the tube. The carrier is larger so again out of luck. The pintara has 25 spline axels, howeve again I doubt if thety fit as the RT141 is a 23 spline axel. The pintara and skyline diff is a Borgwarner 78 series the rt141 is a borgwarner 70 series.
for coilovers
i would highly recomend this setup at the front
im running mx73 struts, with a steel sleve welded on, st185 inserts (kyb-agx ones), and s13 camber tops
this bolts in perfectly! im running 8kg springs up front
japlish - what sierra shocks are you running in the rear? im still trying to sus my rear end suspension and can't decide what I want to use.
I need something relatively short stroke as the car will be sitting very low.
I'm also running a ra60 t-series diff for the option down the track of a 2-way lsd. This will reduce the stress on the axels while driving normally!
I'm running GH sigma arms up front too, and they give a MASSIVE boost to your front track and give you about 3 degress of neg camber!
I need more adjustment to tuck my 15x8's in under the standard guards.
I think they are about 30 - 40mm longer than the rt142 control arm.
I'm running an AJPS lock spacer up front, however I might ditch this as it has added way too much steering travel now. I want more lock without extra turns k thanks!!!
I'm halfway through adapting s13 castor rod mounts to an rt142, seeing as ae86 castor rods are extremely overpriced!!!!
When funds permit (read after i've bought a house and settled in...) i'll be doing a coilover rear end! So sit tight!
Oh yeah, power wise. I'm still running a 22r... mind you, it does have twin 40mm solex's and a few other goodies, I'm sure it will slide just fine!
Also running an oil cooler too, because QLD heat sucks!!!!
Thats the answer i was after thanks mateOriginally Posted by 3jcelica
It looks like hilux rear end is the way to do, i was hoping to use the corona diff housing to save doing more custom work.
http://img.photobucket.com/albums/v4...wphotos001.jpg
engine bay pic
Mookie
any other rear end options other than hilux that anybody can suggest ?
