Results 1 to 5 of 5
Thread: RCA's for MX73 MX83
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    Default RCA's for MX73 MX83
    I have found some RCA's for MX73 on Techno Toy Tuning, although I am unsure on the height of them. I am waiting on Gab from T3 to email me back with the dimensions.
    In the meantime, I came across a Cressida drift site that sold RCA's in 30mm & 50mm heights, but cant for the life of me find the site again.
    Does anyone know if RCA's can be purchased for MX73 in Sydney. I was thinking Whiteline, but couldnt find a listing on their site.
    Junior Member Domestic Engineer Viper's Avatar
    Default Re: RCA's for MX73 MX83
    I got mine from T3. 50MM.
    MA61, so probly be the same for MX73.
    Hope that helps.
    Only place I could find that sold RCA's and were readily available.
    Daily: '06 Liberty 3.0R specB
    Project Car : '84 MA61: 2JZ-GTE + 6 Speed
    Quote Originally Posted by TA22 1MZ
    How low is your car?
    If it is not that low then don't bother with RCAs.
    Quote Originally Posted by amichie
    If you have lowered your car 50mm and there are 50mm RCA, I'd use them.
    McPherson strut cars quickly end up with sub-terranian roll centers when lowered and quickly loose negative camber (gain positive camber) on suspension compression once the the lower ball joint is higher than the inner pivot point. Static wheel alignment can only help so much with the excess positive camber gain on compresion.
    Quote Originally Posted by Viper
    Hope that helps.
    Thanks mate, I have enquired about the MA61 50mm as they have the same 90mm spacing between bolt holes as MX73. They only have a 35mm thick version for MX73.
    definitely need them mate, took 50mm out of my struts for coilovers and shortstroke conversion, struts dont even go close to bolting up atm
  1. 1jz Jzx81 -> Mx83 Abs
    By mamba in forum Tech and Conversions
    Last Post: 21-11-2007, 08:28 PM
