Dont just get a few seals and a VRS kit, get the full kit. The full kit will include all gaskets, seals etc, vrs kit, pistons, rings, bearings. From there you need to get a timing kit, make sure you get the guides, chain and sprocket. I would say throw in a new water pump for good measure, and a new oil pump. You probably wont need to get the crank machined, just linished, but i would say that boring and honing the block to accept oversized pisons is the way to go. Also, getting new gudgeon bushes and fitting them will help too. These will need to be installed by a machine shop. Get the crank and flywheel balanced, and get the flywheel machined. New engine mounts including gearbox are the go. Balancing the con rods is a good idea too. The valves should be either replaced or re-seated, and new valve springs are a good idea too. While your at it, maybe look into a camshaft with a more aggressive profile (either higher revving or torqueyer, the original was conservative, and restrictive). Porting is a good idea too, but this can be done at home. All the head shop will need from the vrs kit is the valve seals, so make sure you give them over with the head.
It can be a big job, but if your gonna spend the money, might as well do it the whole hog.
