inneresting..
when you mash pedal, all that will happen, regarding oil, is that the crank gets pushed down further...
the oil inlets to main bearings is also on top of shell , so... maybe it is the opening of the top clearance? seems rather odd tho. even with thatm it shouldn't be shedding so much out the side of the bearings that it actually causes oil pressure to drop.
if it was crank case pressure backing up, from blowby, it should increase oil pressure if anything.
do you have that exhaust sucker still on? you think it could provide 10psi suckage?
if it was crank case vacuumage, then it will suck oil out of everywhere, and increase shedding rate....
can you put a vac gauge temporarily on the crankcase or cam covers or something?
