Results 16 to 22 of 22
Thread: Paradoxial drop in oil pressure with throttle... ???
    vic
    Default Re: Paradoxial drop in oil pressure with throttle... ???
    Struth 3 thou is far too large .Who suggested those clearences?
    1 thou big ends and 1.5 thou mains MAX .
    Dave
    Penrith BC
    youre dreaming dave. seriously. 9500rpm is a completely different engine to whatever it is your thinking about. different bearing tolerances, different oil dynamics, different loads, different temps...
    ../delete/ban
    tech moderator
    Jan 2007
    Quote Originally Posted by cambelt
    Dave
    Dave,
    I would suggest that you have had limited experience with race engines based on a production block.
    A Cosworth BD series would be lucky to survive a single lap at your suggested clearances !
    I have found that a 1UZ with std clearances will not survive at 8000 rpm, let alone 9000/10000 rpm.
    So far as I know, Ed and myself are the only private 1uz's with max power above 8000 rpm and turning in excess of 9000 rpm. Both engines N/A and no nitrous, both well in excess of 500bhp at the flywheel.
    I stress that 9000/10000rpm is also alot to ask from a standard oil pump
    I spose it depends on how good the stock oil pump is, which i have no idea about.
    I saw similar things with my electric oil pressure gauge, inexplicable fluctuations based on throttle input and other non-relevant factors. I fixed it by running an earth wire directly from the gauge to the body of the pressure sensor; apparently earthing via the block isn't good enough. Maybe give that a try, it's easy to test?
    vic
    Yes you are right i havent had a lot of racing engine experience but 3 thou big ends , I spose it also comes down to how a engine is run in and if one wants to spend 20000klm running a tighter one in . Also depending on what sort of job is done on keeping everything straight when machining .
    I can chime in in saying that 3 thou clearance will use more oil supply than at 1 thou for the same pressure. And 3 thou will grow once its run in.
    Dave
    If the oil is doing its job, the clearance should stay the same throughout engine life. Regardless of run in or not
  1. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  2. 1jz Oil Pressure
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 23-01-2006, 03:32 PM
  3. jza70 intercooler pressure drop
    By atomic rob in forum Tech and Conversions
    Last Post: 22-01-2006, 09:34 AM
  4. 3SGTE oil pressure maybe low?
    Last Post: 12-01-2006, 03:40 PM
  5. engine pinging
    Last Post: 15-12-2005, 12:15 PM
