Results 1 to 15 of 19
Thread: valve shim adustment tool
    Default valve shim adustment tool
    hi all,
    i need to whip out a couple of valve shims from my 4ag given how tight the 4ag head is its a real pain to get a screw driver in there to lever down the bucket. i fashioned up a nylon wedge and spacer to try and do the job but struggled to keep it in position correctly.
    i tried to get a shim depressing tool but couldnt get my ahnds on anything eaisly. does anyone have one of these
    snapon YA8825
    or the toyota equivalent 09248-55010
    does anyone have one they would lend me or know where i can get one at a sensible price im really not in any mood to pull the cam shafts out.
    Default Re: valve shim adustment tool
    I have one you can borrow. Pick up from Dee Why or Redfern.
    There is a second tool you need.
    I've never used it, but after my last shim job (1UZ) I found it easier to remove the cams completely.
    I started with loosening the cam caps and raised the cam 5mm, but couldn't flick out any of the shims. Even with the cams completely out I still had a lot of trouble removing the shims.
    4A might be easier though. 1UZ just might be a price.
    The Toyota tool is about $350ish
    The SnapOn is about $90ish
    You can get them of USA websites for about $70 plus post.
    wow $350 for the toyota one ... erk.
    i can find copies of these tools on us-ebay but no-one that ships here. and everyone i speak to locally doesnt have them,.
    i dont really want to pay $100 for it given i dont really see myself using it particularity regularly. if it was a spanner id just buy the thing.
    amichie you have pm/.
    teq Grease Monkey
    California
    Here in the states you can get copies for less than $20 usd from ebay. Too bad they don't ship internationally
    Made by powerbuilt/alltrade tools:
    648829 Valve Adjustment Tool
    http://www.alltradetools.com/index.h...id/765/lang/EN
    Andrew
    I got mine from the snap-on van for about $80 maybe 5 years ago.
    *** We're sorry. This item can't be shipped to your selected destination. You may either change the shipping address or delete the item from your order by changing its quantity to 0 and clicking the update button below. ( See geographical restrictions.) ***
    not sure why why regardless given the dollar conversion $30US + freight i may as well buy the $100 snapon tool locally. which is what im trying to avoid given the cost per use
    Chiba
    Damn, I needed one of those last weekend. Spent hours installing and removing the cams in my 4AGZE to get the shims spot on.
    do they scratch the cams or shims?
    They don't touch the shims, or the cam lobes, so no.
    No. I guess they are softer than the shim material.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Did you try using a little flat blade screwdriver in the little cutout in the bucket? Has always worked for me on all the Toyota engines I've reshimmed (read: lots).
    Failing that, a magnet on a stick and a blast in the cutout with a compressed air gun does it too.
    oh.. i was trying to imagine how it pushed down the buckets and shims, without touching the buckets or shims or cam??
    or.. edge of bucket and cam off the lobe? (these new car things confuse me )
    Quote Originally Posted by Gavatron
    1UZ shims don't have cut outs.
    They have a ~2mm hole drilled in them.
  1. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Last Post: 29-02-2016, 12:30 PM
  2. DIY: 4age Valve Stem Seals.
    By assassin10000 in forum Tech and Conversions
    Last Post: 09-08-2013, 09:14 PM
  3. Valve Lapping/Grinding Writeup
    By RobST162 in forum Tech and Conversions
    Last Post: 07-01-2009, 10:55 AM
  4. Bucket Shim vs Valve Sprung
    Last Post: 04-09-2007, 10:35 AM
