Results 1 to 12 of 12
Thread: SA63 Celica brake upgrade please help
    Junior Member 1st year Apprentice moggie's Avatar
    Feb 2009
    Default SA63 Celica brake upgrade please help
    I need help with what options there is for brake upgrades on a SA63 Celica
    I was reading that you can use nissan hubs and struts for the front??? Is this correct?
    I cant seem to find much information about brake upgrades for the rear (drum to disc), do you have to fabricate yourself, ( I don’t mind having to fabricate my own setup its just a lot easier of there is a bolt on upgrade)
    I anyone can give some advice id appreciate it.
    Default Re: SA63 Celica brake upgrade please help
    Is this for a track car, or just want some better stopping power on the way to the shops?
    How much you want to spend?
    Track car, S13 front gear, RA65/RT142 rear end with MA61 brakes - or even better search what the MA61 guys are doing for rear brakes (R33 gear).
    Feb 2009
    It will be used on the street and track, to get it mod plated i need to have 4 pots on the front and dics on the back. I am doing a 1jz conversion.
    Front end:
    -The cheapest way would be the hilux/pug conversion, that gets you 4 pot front (search for it on this forum).
    -More expensive, but better is to get S13 struts/hubs and then upgrade the brakes to R33, you need to find a LCA that works, S13 will fit but is very long, gives massive neg camber, i think people use MX32 or some other cressida? Search S13 struts/hubs.
    Rear:
    MA61 gear can be adapted, or RT142 corona avante. I suggest swapping in a RA65 rear end in first cause the SA63 (although very similar) has a smaller diff, and no LSD option. RA65 has common F-series diff (7.5" crown) and lots of OEM and aftermarket LSD's.
    New Zealand
    For SA63, you may find it already has the 100mm caliper spacing you need. If not get the front end components out of an MA61/RA65 that let you bolt up Skyline 4 pots. Search out MA61 upgrades, there are heaps of threads on the brake swap.
    Callum
    Feb 2009
    Thanks guys for the help, I have a good starting point now.
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    Quote Originally Posted by Screamn_Sleeka
    Rear:
    just to point out, the RA65 rear end, although it has an F series diff, is drum brake rear end, and the swingarms will not be able to use discs/calipers.
    suitable candidates for the swap are RT142, MA61 or MX73. though i think the MX73 rear subframe is wider than the first two and will push track out ~10-20mm each side. the swingarms are the same though, and they have the same discs.
    RA65 needs MA61 gear to make disc, as i said.
    May 2006
    ah my bad dude... glossed over that bit :\
    Victoria, Mt Macedon
    Excuse my ignorance if wrong, but I thought SA63 was live axle. If so then you can do the old *T14* Corona disc swap onto the rear. GA61XX wrote a how-to on it a while back.
    On the front I think your struts should have the same caliper bolt spacing as Nissan calipers, and so open up a huge range of options.
    Hen
    Feb 2009
    Hen
    Yes it is IRS
    thanks for bringing this up it was going to be my next question after looking into some of those options.
    New Zealand
    Hen
    I've seen an SA60 and a TA61 both without the 100mm spacing (were 90ish mm from very very vague memory) so there are variations. These were both Jap spec though, don't know what Aussie got.
    Callum
    By The Witzl in forum FAQ
  2. brake master adjustment? after s14 upgrade
    By sam-131 in forum Tech and Conversions
    Last Post: 18-02-2007, 11:25 PM
  3. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 10:26 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
