Nope.
It's possible to work it out though.
Easier for you to read than me to try to explain.
http://www.jameshakewill.com/cg-height.pdf
Got your jack handy?
Hey Bill, did you ever work out or do you know where the COG of the AE86 is?
Nope.
www.billzilla.org
Toymods founding member #3
On the top pic (the watts linkage) how do you deal with the problem of the arms of the watts linkage effectively shortening when the whole axle moves upwards? is there simply not enough travel for it to be a problem?
-RM.
Originally Posted by mullett
The Watts Link pivots, easy.
www.billzilla.org
But it's fixed at both ends? So as the centre pivots upwards, it pulls the two ends inwards?
-RM.
Each end is joined on the opposite side of the pivot point so they are both move in opposite directions.
Callum
Yep - and the Watt's Link pivots.
www.billzilla.org
Hmmm... apart from the fact that i have very little room in my current garage (damn single car garage), my sprinter is an empty shell sitting 800mm off the ground bolted to a trolley that was used to get it sandblasted and primed.Originally Posted by Billzilla
Am doing some suspension design at the moment for an independant rear end for it. The outboard points are courtesy of s13 silvia uprights, and i'm trying to figure out the best compromise between where the inboard points will physically fit, roll centre migration, roll centre height, camber gains, etc. Also doing stuff with the front end, but currently sticking with the mcpherson strut setup, which somewhat limits how good you can make the front end setup.
If i had a good idea of where the COG was, i'd have a better idea of where reasonable roll centres would be for the car.
Unfortunately i'm a bit of a noob when it comes to suspension stuff (more of an engine person traditionally).
Anybody else with a sprinter feel the need to find the COG?
Ah, gotcha. That's the first time I've looked at one up close, it looked like the two inner ends were on the same bolt. Effective setup!Originally Posted by Billzilla
-RM.
How does that setup go? Bit flighty in corners?Originally Posted by freddo__1
And while you're at it, change brake and clutch fluid - emptying the m/c reservoirs has never been easierOriginally Posted by Billzilla
(Yeah, that's an implied warning to check any loose fitting caps before nearly turning your car on its side...)
'73 TA12 Carina - pushrod power project
'77 TA14 Carina - 1GGTE swap in the works
'77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
lol, being on four pivoting castors it goes sideways really well!Originally Posted by af300e
(getting on the trailer to go to the sandblaster)
