If that's what you think, that is what I think because I can hardly guess, and anything might be possible.Originally Posted by Ryan1980
It is unlikely that the transmission extension housing needs replacement, only a seal if it's a seal problem, and a bearing And seal, if the bearing has so much play & slop, whether it's a sleeve or ball bearing, that it would quickly wear out a new seal.
Does 'tailshaft' mean propeller or driveshaft? It is likely that you need a new tail shaft or at least new U-Joints on a 1980 with ?Km. Is it the tailshaft's yoke that slides into the transmission that is loose& wobbles around & leaks? Does the place on the sliding part that meets the extension housing seal look & feel heavily grooved or smooth? It might be fixable with a file & emory paper.
