Diffs should be a direct swap, I am almost 100% sure, but someone else may confirm.
I currently purchased a parts car with an LSD in it. My daily driver is open centre and am going to swap diffs over. All the mounting of the diff and the tail shaft end seem the same, but do i need to use the LSD C.V. joints? Are they different from open centre ones? What else is different? Or is this basically a straight swap?
Cheers, Judd
once you drop your diff out, you'll be able to see if it will be a direct boltup
from memory, the LSD and open for the ma61 are identical from the exterior apart from that cool LSD oil sticker you have
As stated. Identical! (assuming that both your supras are AUS del / have F series diffs, none of this JDM T series XX junk!)
Also for future reference if you need a cheapy replacement or a ratio change, the 4.1 F series from a MX73 cressida or the 3.5 F series from a RA65 will both slot straight in![]()
And for more future reference (aimed at wilbo666!!) not all JDM XX's came with a T series diff... I have a F in my XX from factoryMine came with a 1G-GE instead of say, JCMF's which had a T standard.
The diffs in these cars are easy to work with too, you should have no troubles.
Hydra
JZA61 Celica XX
Provided it's a F series sub-frame and diff in your car, if not it sux ass, believe me, I know!Originally Posted by Hydra
I'll agree with that!
The only pain with the F is going to the local wrecker only to find every car with an IRS F series diff has had the damn diff removed![]()
Hydra
JZA61 Celica XX
Ahff, I wouldn't get too stressed about that, every MA61 diff I've ever seen has the LSD completely shagged anyway - they were set up rather loose from the factory, and only wore out from there.
I just want the housing, and gears!
Hydra
JZA61 Celica XX
Originally Posted by mrshin
Hence my advice on cheapy open centre replacements. Now why dont you go headbutt a pooltable![]()
Only if we can stop off at the kebab caravan afterwards!Originally Posted by whatthe?
See my last post then, they go straight inOriginally Posted by Hydra
Deal, if your stomachs contents stay in thereOriginally Posted by mrshin
Yes, but every time i've been to the wrecker people take the whole lot at once...Originally Posted by whatthe?
Hydra
JZA61 Celica XX
