Results 1 to 15 of 23
Thread: MA61 Open Centre to LSD
    Wazzzzup!? 1st year Apprentice ToranaJudd's Avatar
    Question MA61 Open Centre to LSD
    I currently purchased a parts car with an LSD in it. My daily driver is open centre and am going to swap diffs over. All the mounting of the diff and the tail shaft end seem the same, but do i need to use the LSD C.V. joints? Are they different from open centre ones? What else is different? Or is this basically a straight swap?
    Cheers, Judd
    TAS
    Default Re: MA61 Open Centre to LSD
    Diffs should be a direct swap, I am almost 100% sure, but someone else may confirm.
    once you drop your diff out, you'll be able to see if it will be a direct boltup
    from memory, the LSD and open for the ma61 are identical from the exterior apart from that cool LSD oil sticker you have
    As stated. Identical! (assuming that both your supras are AUS del / have F series diffs, none of this JDM T series XX junk!)
    Also for future reference if you need a cheapy replacement or a ratio change, the 4.1 F series from a MX73 cressida or the 3.5 F series from a RA65 will both slot straight in
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    And for more future reference (aimed at wilbo666!!) not all JDM XX's came with a T series diff... I have a F in my XX from factory Mine came with a 1G-GE instead of say, JCMF's which had a T standard.
    The diffs in these cars are easy to work with too, you should have no troubles.
    Quote Originally Posted by Hydra
    Provided it's a F series sub-frame and diff in your car, if not it sux ass, believe me, I know!
    I'll agree with that!
    The only pain with the F is going to the local wrecker only to find every car with an IRS F series diff has had the damn diff removed
    Montrose
    Ahff, I wouldn't get too stressed about that, every MA61 diff I've ever seen has the LSD completely shagged anyway - they were set up rather loose from the factory, and only wore out from there.
    I just want the housing, and gears!
    Quote Originally Posted by mrshin
    Hence my advice on cheapy open centre replacements. Now why dont you go headbutt a pooltable
    Montrose
    Only if we can stop off at the kebab caravan afterwards!
    See my last post then, they go straight in
    Deal, if your stomachs contents stay in there
    Yes, but every time i've been to the wrecker people take the whole lot at once...
    By The Witzl in forum FAQ
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  3. IS200 Altezza Type 2 Torson LSD into MA61 IRS F series?
    Last Post: 27-12-2005, 08:53 AM
